I have the following number for a 996 GT3 front sway bar: 996.343.701.90. The bushings are 996.343.792.16. I've seen this spec'ed at 26.8mm diameter, but a Porsche dealer told me this is wrong. Anyone know what the real outer/inner diameters are? If not and someone has their GT3 up in the air, could they measure? The important measurements I'm looking for are outside diameter (I can estimate for paint thickness), the thickness of the crimped end where endlinks bolt (to estimate bar wall thickness), and length between the bar ends (crimp-to-crimp). The diameter measurements are critical since the stiffness is proportional to the ^4 power. There are a lot of bars out there, and this would help in an apples-to-apples comparison. Thanks!
