I have a question in reference to the feature that steps the window down when you open the door. Is this the window regulator? My motor works perfect and when the window is lowered half way the glass will step up and down when the door is opened or closed, but fully closed it gets jammed. Can some one help?
:renntech:
you'll probably get more help in the boxster (986) section than in the 924/944/968 section - those things are very likely different setups between the two very different types of cars
