i bought durametric cable and software and i checked my car for the first time
Porsche Access System - PAS
Current Fault Codes
8004:
Terminal 50
Value below lower limit value
8053:
Electronic steering column lock continuously blocked
Upper limit value exceeded
could someone explain me about these codes?
also i read that i have Number of ignitions range3 5 / 720h but i dont know how i reached these revs(range 3=7700-7900 RPM)
i cant rev up to 7200-7300 :huh:
Rev ranges have been an extremely well covered topic here on the Forum. You should search and read through some old threads.
Here are the rev ranges for your car:
A 997-1 DME records the following rev ranges:
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
Range 1 and 2 are very common. A few ("few" being the operative word) ignitions are OK in range 3. Ignitions in range 4-6 spell "T O A S T " for both your engine and warranty.
How do you get "safe" ignitions that exceed your rev limiter? That happens from the momentum and inertia of your engine. How do you get ignitions that exceed range 3? Mainly missed shifts or spinning the car (get clutch in asap). The rev limiter only protects on the way...not on the way down (missed shift).
