Hey guys,
I have a 2000 996 C2 Cabrio Tiptronic. Maybe it was always like this and I never noticed, but now when the car in in "D", after the car shifts from 3rd to 4th (or) 4th to 5th, around 2000 RPM I see a blip in throttle, its almost like the RPM slips for like 200 or so RPM, then it climbs really strong. I havent noticed it in "M", but thats not to say it doesnt do it I guess.. My experience with engines is mostly american V8s and I know that most of those transmissions have a Tq converter lockup which is like a lockup on top of the final gear, does the 911 have something similar? or is it a problem.
If I go through the gears and only shift in high RPMs I dont see this. Its only when I leave it in auto and cruise, it slips / blips (like its downshifting)..
It's indeed the lock up you feel, a typical Z.F. Tiptronic issue, it does no harm just annoying. You can check the fault codes, if there are, for piece of mind.
Thanks for the response RFM, This is the exact feeling, Even in M, I drive slowly (not flooring the throttle). 1->2->3->4 goes without incident. On both 4th and 5th gears after shifting if it was cruising @ 2000RPM I feel it blip sometimes, now if I was flooring the throttle on 4 and 5, I dont see that blip, it climbs rapidly.. the blip is about 100~200RPM to be exact happens only on part throttle cruise @ 2000RPM (nowhere else in the RPM band).
Its bizzare that the manual never mentions of a lockup converter..
I was thinking of getting 2 litres / quarts of transmission fluid and seeing if the fluid is low using the apparatus described in the Maint forum. Should I even bother?. How often does one need to flush the system?. The car has 75k miles.
A.T.F. fluid + filter replacement never hurts, use the approved fluid and a filling device is recommended (DIY is on the board) gearbox temp. must be 40° C. (105° F).
