Hi, I bought a oem mkII gt3 bumper cover as a replacement for my damaged one,
and they look the same but part #'s are different, and so Is the headlight trims and the lower lip ls shorter then the one I had..?
So new one has 996 559 983 Z0, headlight trim 996 505 742 01
my damaged one 996 505 983 02, and headlight trim 996 505 742 02
thanks
You are likely looking at assembly numbers not finished part numbers.
Do they look alike? If so, just use them - there were minor changes during MY03-05 GT3.
