Looking for some advice on what brand of car seat (front facing, for 2.5 year old) fits in the rear 997 C2S seat. I tried several types and they were all too large. Any advice would be greatly appreciated!
Depending on the size (height/weight) of your child and state laws you may be able to use a booster.
For an actual child seat you can use a Britax Marathon. It is a tight fit and removing the seat cushion bottom of your rear seat helps. The hardest part is finding a a car seat with a base that will fit in the bucket area of the back seat. The front seat has to be moved pretty far forward for it to work, but it does fit. I image some of Britax's smaller child seats would probably fit as well. There is actualy a latch point back there in the middle of the rear shelf which is nice.
I recently switched to a booster seat, a Recaro Vivo. It is a better fit back there, but it's just a booster, so if you kid is not big enough or state laws, that may not safely work for you.
Good Luck,
larez2
36lbs, 36 inches, A booster uses the original seatbelt as the restraint. I am looking for a seat with a 5 point harness that fits well into the seat bottom "bucket". I tried the marathon but the seat fits somewhat angled and the lower seat belt attachment is angled forward, not up so it only compounds the problem.
With a booster the seatbelt crosses her too high on it's way back up to the retractor (she is too short)
I have a 2006 C4S coupe and put a Britax Roundabout for my 2.5 year old. Fits perfectly, nice and snug (she weighs 30lbs)
Edited by w00zie
Thanks, Did you remove the lower leather seat?
no, left it there and bought a seat protector with grip so the seat wouldn't slide fwd
