hi all,
i need your help,
i am installing 996 TT brakes on a Carrera 2 01, front and rears.
can anyone tell excactly what parts i need?
please, since i have posted the same topic @ rennlist.com, reply with an answer that matches the question. the replys i did get before were for GT3 calipers, for carrera 4...etc.
please help. :huh:
harris
Cast iron or Ceramic?
You will need rotors, calipers, and front wheel carriers from a MK1 GT3 or GT2.
The TT front wheel carriers (hubs) will not fit on a C2 as they are for 4WD cars. So you need the front wheel carriers from a 2WD car.
Not only can you only use gt3 fronts to mount them but the turbo setup is extremely heavy and any benefits you get will be erased by the weight plus it will mess with the unsprung weight. If you go this route look at the brembo kit that is super light- it's better and lighter-
