I secured some Champion Motorsport 20" wheels for my '06 997. I was wondering if anyone can help me with correct tire pressures?
I would start with what the manual says for the 19's it came with. I believe it is 42 for the fronts and 44 for the rears. See how that feels and you can always adjust based on the feedback you're getting for the car. You might want to get in touch with a good tire shop that does high end cars. The guys at Tire Rack are also very helpful.
Pressures for the 19" wheels are 33 front and 40 rear. However, with the lower profile rubber you may want to to the high side of the spec which would be 36 front and 44 rear.
