Hi all,
Well got back home safe from euro road trip.But on the way theses lights came on the dash!
first the Break Pad Ware, then the PMS OFF, followed by the ABS light.
Had it checked by Porsche Centre France and they said that the pad’s & fluid are all fine(only new)
and that they think it’s the (Sensor Ware Contact) that's to fault, and that it’s no danger.
Mind you I did drive 4282 mile’s (6892 km) with no problem’s with the break’s.
From Ireland all the way to Poland & back
via a few stop’s in south France, Swiss, Austria, Germany & Belgium. All in 4 weeks.
The package I used to change the Pad’s & Disc’s front & rear is:
4 x Brake Disc (SEBRO)
2 set x OEM Brake Pads (TEXTAR)
4 x Brake wear sensors
+ Brake pad dampering shims
What do you’s think the problem could be.
Thanks in advance.
post-26847-1252061005_thumb.jpgon the autoban all is happy Oil, Coolant, but not the light's
Edited by JamesD
Now thats what I call a fast reply,thanks Loren.
Will do, I'll check them out tonight.
And post back later.
