Last week I received a P0446 CEL code, after some searching on this site, I cleared the code and filled the gas tank. Yesterday I received P0445, so I dropped off at the dealer. A smoke test revealed leaks in the charcoal canister. I thought I'd post this "smoke" test since I hadn't read about this before. Hope this helps someone else out.
P0445 EVAP Canister Purge Valve – Short to B+/Short to Ground
Short circuit to B+
Short circuit to ground
– Wiring harness
– DME control module
P0446 EVAP Canister Shutoff Valve (Function) – Below Limit
– Purge air line blocked
– Flow resistance of EVAP canister too high
  • 2 months later...
Two months for my dealer to receive the carbon canister from Porsche! My original canister failed causing these check engine codes. In addition, cold engine caused a very rough idle until warmed up. Idle would chase after warmed up. According to my dealer, both were due to the failed canister Hopefully these issues have been fixed.
Parts replaced:
955-201-081-02 Carbon Canister
955-201-908-00 Moulded Hose
N-100-232-91 Hose Clamp
  • 4 months later...
Parts replaced:
any update on this?
