Hello :(
Switch ignition on (do not start the engine) The engine-oil level measurment appears in the on-bord computer.
This is in the manual book. But in my 2009 carrera4 DFI nothing appears if the ignition switch on and engine not starting. i can chick only when the engine is running is that normal ? even oi is hot.
Thank you
Edited by maximumboost
End must be running and warmed-up. Car cannot be moving and you must be wearing the seat-belt to check the oil in my C4S.
