On the first pic, taken of the front pads, are these the pistons from the calipers? Mine were stuck to the pads. Is that normal? Should I reuse them or get new pistons?
On the second pic, what metal part is the arrow pointing to? Do I need to keep that and reuse or is that a part of the pad that can be thrown away?
Those are the retaining springs that help holds the anti-vibration dampers in place.
Have a look at the brake DIY here for more pics.
thanks Loren. Also, do you think I should replace my dust gaskets and the inner gaskets?
If they are cracked or split - I would say yes. Otherwise I would just check them next time.
Thanks. That's what I will do.
