I have seen on various forums here, that a fuel injector cleaner is highly recommended.
Is there any specific make etc etc that is recommended for a 99 Carrera 3.2 Coupe. ?
Any of the brand named one are very good. I use them about once a year. By the way...if you use the WRONG kind, your engine's cylinders will start to shrink. Looks like your has already started. You used to have a 3.4 liter engine.
:lol: :lol: :lol:
jimmyq is just joking.
I use Chevron every 4-6000 miles.
Techron concentrate by Chevron- 8 oz for about $6.00. Just add to tank.
Make sure it's the concentrate formula, they have a more dilute cleaner which "contains" Techron and is cheaper but doesn't work as well.
3M makes a fuel system cleaner kit with 3 parts, a add-to-tank cleaner like Techron, a spray cleaner for the cleaning the throttle plate area, and a combustion chamber cleaner that you inject into the intake manifold through a vacumn hose (pcv valve)
Regards,
BD
