Custom Catback with Magnaflow Mufflers
I did a new catback as some allready did to their cayenne's. My car is a 955 CS. I used 2 Magnaflow mufflers 14226, which are 14" body and 4 mandrel bent elbows - 2 of them on 90 degrees and 2 on 60 degrees, Magnaflow mufflers are Center- Offset type for out-in I would have went and tried the 18" bodies but the local shop didnt had them. the sound is very nice, still I have some rattle when they are cold at 4krpm. But the inside cabin sound is nasty and I love it. Also I dont have 2ndarry cats
Edited by stealthTT
  • 7 months later...
I did the exact same set up and this was my cost:
2 MagnaFlow mufflers - $160 shipped (eBay)
2 2.5" 90 degree mandrel bent elbows $55 shipped (eBay)
Labor charge from Old Gold exhaust shop in my area $93
I didnt use the 60 degree elbows because if you have the stock exhaust cut off right at the muffler there is plenty of bend there for the welder or exhaust shop to use with the 90 degree bends. Sounds great coupled with my Leistung Motorsports cat bypass pipes.
You said this is fairly cheap? How much did it run you? If you dont mind me asking
