Help!....can someone tell me where the Evap Purge valve is on the boxster (2000-986). I have seen the diagram where it is located on the 996, just doesn't seem to be in the general area. Is the line going into the Throttle Body?....If I knew that, I could find it.
Thanks in advance!
2000 986
2.7
5-sp.
Yeah, I have gone through all the evap threads....that diagram doesn't tell me much about where it enters the manifold......If I knew that, I could find it....
Thanks for your help!!!!!
I found it......if anyone wants to know....it is directly underneath the driver side intake "plenum".....with the line going into the the intake, right after the throttle body towards the passenger side of the car.
