I am having a weird timing problem with the starting engine when starting up. Most of the time I get a clean ignition but maybe 1/4 of the time my start-engine seems to keep on starting right after the engine is started and gives a very bad sounding squeek for a half a second.
Any ideas what causes the problem and how to fix it?
Probably a beginning starter motor fail, a rebuild or repair will give the most satisfaction on long term. You can try to lubricate the starter driving gear and axle, without any guaranty, you have to remove the starter in all cases.
Trying to lube the bushing is only a short term fix and as RFM stated it's best to replace the unit or have it rebuilt correctly.
This will be the starter - but dont ever lubricate it.
Lubrication attracts dust - the operating environment it is in is full of dust from the clutch, mix that with lubrication and you will get a gunge that will clog the starter and create the same problem you have now.
Chances are it is this gunge that is causing your problem now.
The starter pre-engages before power is applied to turn the shaft, once the engine starts and you release the start position of the key the solenoid deactivates and draws the gear away from the ring gear of the flywheel.
Remove the starter and wash all the working bits in petrol (gas to you) nothing else is needed, blow it dry with an airline ir simply leave to stand until dry - then refit - problem solved
