I am new to both Porsche ownership and this forum, so please forgive my apparent ignorance to both.
I have a 1999 911 Carrera and the check engine light has just come on.
In anyones experience, what are the most common reasons for this light to come on. Could it be the spark plugs or maybe something a little more serious concerning the catalytic converter
From what I have been seeing on Porsche forums, a typical CEL can be caused by:
- An oxygen sensor tripping due to too much/not enough air in the mix.
- A faulty MAF (again, emissions related).
If you search a bit, you will find these too. Also, if you have an AutoZone around you, they will get you the P code. The problem they tell you related to the P code may not be correct however.
A list of P codes can be found here:
P Codes
Searching these forums will be your best resource.
Good luck,
Darren
:beer:
Edited by Mitty
:welcome:
A CEL is not an uncommon occurence in today's cars.
Some of the most common causes of this (emissions) warning are:
a loose gas cap (or bad o-ring on the cap)
a loose oil filler cap (or bad o-ring on the cap)
These would be the first two things i would check. Make sure both are clean and secure. The CEL light can be reset by anyone with an OBD II scan tool in about 5 secs. Alternately you can disconnect the battery for about two minutes and reset it also - but you will need to re-enter the radio code and stations if you do that.
Anyone in the Chicago area and know of an Auto store that has an OBDII scan tool and will scan the codes for me.
Thanks a million Loren and Mitty for your replies so far !!
A follow up regarding the CEL light on my 1999 Carrera.
I found an AutoZone in my city, and they ran an OBD II Scan for me. It came up with error code P1531. I checked out alldatadiy.com and it lists the fault as :
Camshaft Adjustment, Bank 1
Function - To increase torque and improve cylinder charging, the engine is equipped with two VarioCam actuators
I am just starting to learn about the Porsche engine, so is there anyone out there who knows how serious a problem this is ? and what steps I should take
:help:
