hi folks,
i have looked at every post I can find on this, and talked with my dealer, showed them the TSB, etc. but there is still a disconnect somewhere.
I have an 04 s. according to the TSB, starting with MY 04, the wiring harness from the fuse box is there as standard equipment(suppossed to be located above the wheel well on the right rear side behind the access panel).
I found the part numbers via this site to order the module, harness, and 7 pin connector.
I had the Curt hitch installed last week.
the dealer is telling me that the parts will get the harness from the fuse box connected to the controller, and the harness part number will run from the 7 pin connector to the OEM hitch connectors.
what I can't get is the integrated harness in the OEM hitch that connects from the control module to the 7 pin connector, they are telling me.
I am trying to understand how people that get the Curt hitch, the module, and the wiring harness get this connected to the 7 pin connector????
I only need lights for my trailer, no brakes. This seems like it should be easy, but with Porsche, I have found, nothing is straight forward.
Can someone please enlighten me? I can't tow until I get this figured out.
thanks so much.
Jeff
Sorry I don't have the answers for your questions but I know my friend has a hitch on his 05 so I'll ask him what needed to be done.
Just received his email reply and he does have a hitch but it's not wired as the trailer he pulls is only a small one that isn't for road use. He just hauls rubbish and such with it on his acreage. Sorry I couldn't be of any help.
