Just purchased myself a 986 Boxster (2002) with the PCM system. Wanting to know what the score is with the built in phone system? It came with a pay as you go sim card in the slot. Does this mean I require 2 phone numbers, one for the car and one for my phone? Seems pretty pointless if you ask me?
If anyone knows how I can get my current number attached to the system would be much appreciated?
Mick
Depends on the location where you live, you local phone company should give you more information. Most used system, over here, is a dual SIM card. The mobile and PCM (both GSM) use 2 cards with the same phone #, for a slight higher price than a solo card. The downside is, one of the two devices should be cut off, it doesn't work with both on.
