What is the nominal/normal engine oil temp for the 2005 911 2S? I have had this car for just over a a year. Until just recently the engine oil temp has held steady at about 190-200. Now it seems to be creeping up, on a couple of occasions as high as 225. The ambient air temp is in the range of 83 - 90 degrees F.. Last year with similar ambient the temp stayed in the 190 - 200 range. I have checked to insure that the air inlets in th e lower fascia ate free of leaves or other trash. Should I be concerned?
JP
