Did you check the clutch interlock microswitch?
First thing - verified both with continuity check and Durametric
Then battery, Optoma 34R - Load tested, good voltage/charge, good connections.
Then ignition switch - removed and verified continuity through inner and an outer terminal when in start
Checked immobilizer via Durametric which opens and closes based on key position
And finally voltage readings on Solenoid Start Trigger Terminal - the small lug - whic reads +12V when key in start position yet solenoid does not cycle.
Steve
