My '99 996 was at the dealer recently. They told me the throttle did not open all the way. Does anyone know if that is a dealer-only adjustment? If not, how do you make sure you are getting a wide open throttle with full pedal?
Thanks in advance.
99 C2 is cable controlled. If you have an OBDII reader you should be able to see the throttle position. As far as I know, unless there is something blocking the pedal from going all the way down or the cable is stretched, you should get WOT. Look at the cable on the throttle body and make sure it is connected right and there is no play in it. If it is on correctly and the cable is tight, I do not see how you do not get WOT when the pedal is depressed completely.
Note: The cable comes out of it's proper position on the throttle lever very easily if you get any slack in the cable, Slack would be caused if you opened the throttle from the engine compartment using the throttle lever or if there is a binding in the cable somewhere that catches when you let up on the accelerator pedal. The cable may still stay connected to the throttle lever but in the wrong position...and would be unable to give full cable movement to gain WOT.
Good luck.
