They are different for each model.
You will need the DME OBD II service manual for each.
Thanks Loren.
Does anyone have the DME OBD II service manual for 5.2.2 996? If so can you scan in the pinouts or pm me?
D.
I believe this is the DME 5.2.2 can anyone confirm because pin 58 has me a little confused.
1 - Heating of HO2S after TWC
2 - Idle air control valve, closing coil
3 - Fuel injector, cylinder 1
4 - Fuel injector, cylinder 2
5 - Fuel injector, cylinder 3
6 - Ground point 9
7 - EVAP canister shutoff valve
8 - Check Engine MIL
9 - not assigned
10 - not assigned
11 - not assigned
12 - Crash signal (airbag)
13 - knock sensor 1 (cyl. 1-3)
14 - Medium pressure switch (A/C)
15 - Intake air temperature sensor
16 - Engine compartment temperature sensor
17 - Signal, mass air flow sensor
18 - Signal, H02S 2 ahead of TWC
19 - Signal, HO2S 1 ahead of TWC
20 - Ground, speed sender
21 - Signal, camshaft position sensor 1 + 2
22 - Ignition coil, cyl. 4 terminal 1
23 - Ignition coil, cyl. 3 terminal 1
24 - Ignition coil, cyl. 5 terminal 1
25 - Camshaft adjustment, bank 2
26 - Terminal 30
27 - Triggering of DME relay, terminal 85
28 - Ground, electronic system (shield)
29 - Idle air control valve opening coil
30 - Heating of HO2S ahead of TWC
31 - Fuel injector, cylinder 6
32 - Fuel injector, cylinder 4
33 - Fuel injector, cylinder 5
34 - Ground, sender
35 - Coolant fan, stage 1
36 - Coolant fan, stage 2
37 - Triggering of relay (terminal 85), secondary air pump
38 - Version coding (ground for Tiptronic)
39 - Fuel reserve pilot light
40 - not assigned
41 - Knock sensor 2 (cyl. 4-6)
42 - Automatic I/M test
43 - not assigned
44 - Signal, throttle position sensor
45 - Ground, mass air flow sensor
46 - Ground, oxygen sensors
47 - 5-volt supply for mass air flow sensor
48 - Nominal engine torque to TC control module
49 - Ignition coil, cyl. 1 terminal 1
50 - Ignition coil, cyl. 6 terminal 1
51 - Ignition coil, cyl. 2 terminal 1
52 - Camshaft adjustment, bank 1
53 - 5-volt supply, throttle position sensor
54 - Voltage supply for various components
55 - Ground, ignition
56 - Terminal 15
57 - not assigned
58 - Actual engine torque from TC control module
59 - Tuning flap (intake manifold switchover)
60 - Programming voltage
61 - EVAP canister purge valve
62 - A/C compressor On
63 - Triggering of fuel pump relay (terminal 85)
64 - not assigned
65 - Relay of engine compartment purge fan (terminal 85)
66 - Start-inhibit relay (terminal 85)
67 - not assigned
68 - Position switch/clutch switch
69 - A/C compressor requirement
70 - not assigned
71 - Ground, knock sensors
72 - Tank pressure sensor
73 - Oil temperature sensor
74 - Engine coolant temperature sensor
75 - not assigned
76 - Signal, H025 2 after TWC
77 - Signal, H025 1 after TWC
78 - Signal, rpm crankshaft position sensor
79 - Speed signal from ABS control module
80 - Speed signal output
81 - not assigned
82 - Coolant level
83 - Fuel gauge
84 - not assigned
85 - CAN low
86 - CAN high
87 - L wire
88 - K wire
D.
