Hello all,
I have a 2002 996 with 59,0000 miles on it.
I just completed the 60,000 service (spark plugs, poly-rib belt, oil change, air and pollen filter replacements)- using all the helpful hints I found on this forum - thank you!!
while changing the oil, I found small leak of yellowish oily fluid - I traced the source to a hose (see pic above).
Anyone know what this is- and how to replace it? I did find that my hydraulic fluid is low- is this related or not?
FH Merchant
Hi,I think this is for steering fluid-presure line,but not sure.Need to do place around to change it,if is cracked,and maybe low the engine down,no place for tools.
Edited by porha
