SOLVED
hello guy's
i got this code
P0026
Porsche fault code 579 - Valve lift control driver bank 1
any advice is appreciated @loren and all guru's please help i have no ideea what is wrong
Edited by ahamay
I would take a look on that side, perhaps the actuator or sensor is hit, there is not much room between the cylinder head and the sub frame.
thank's RMF
could please advice the location of them,i;ve looked in parts diagram i have and i have found nothing
On top of the cylinder head (valve cover), it's better to look under the car, it will be clear in a minute.
RFM thank's man i have tryed to look but i did not see anything on that area especially tht the exhaust is hit and there is no room left.
i also have tryed to see where this sensor is in parts diagram but i can not found anything
could you please indicate where is the exact location in parts manual?
thank's in advance
@Loren
could you please advice the location or the part number for the part in question(valve lift control driver-sensor-actuator or what it is)
thank's
P0026 Valve lift control, bank 1 output stage - open circuit
Possible fault cause
- Open circuit in triggering wire
- Open circuit in B+ supply
- Solenoid hydraulic valve faulty
Look for the solenoid valve actuator that protrudes from the cylinder head on that side. Check the connector and the wiring to see if it is damaged - and since this was a crash look to see if the solenoid itself is damaged. My guess is a wire got cut or the connector is damaged.
