Last night my 1999 C2 wouldn't start (no power even getting to the starter solenoid, checked the clutch position sensor and it *seems* to be working). Ended up having to push-start it to get it home (thank goodness for friendly people!). I've already replaced the ignition switch, although it was a while ago, and recently replaced the starter drive. Can someone please PM me the wiring diagram for the lines running between the ignition switch and the starter? I'm looking for any relays or fuses that might be along the path as well as where the wires themselves run.
Thanks in advance!
I would check the clutch sensor again,,,,
Here is how it goes.
BATTERY (RE)--->
CURRENT DISTRIBUTOR F4 80AMP(RE/WT)---> *CHECK THE IGNITION LOCK F4 80AMP FUSE
IGNITION LOCK(YE)--->
START LOCK RELAY(YE)---> *CHECK THE START LOCK RELAY SUPPORT REAR
STARTER
I hope this helps.
