Hi
as the title suggests i am trying to replace the corroded and damaged guide tubes that go into the hub carriers i have removed them from the hub carrier but do not know how to remove from the handbrake cables they seem to be molded round the cables but are sold seperatley anyone got any ideas
Regards
Ross
98 boxster manual
I think you will need to completely remove each cable from the handbrake inside and pull it through the guide. Seems not a very common problem.
i have fully removed them but the rubber shield and guide tubes wont go past the gold tip which goes in the to the ebrake clamp i have ordered the guide tubes will post pics when they arrive
