After a few thousand mile's & a few bumpy roads,
I have notice that my right side Exhaust tail pipe tip is about 2 inch's OFF CENTRE & slightly lower than the left one?
I cant post any pictures yet because I'm on vacation & am using the hotel computer.
Has anyone had a similer situation and any advice on how to fix this.
Edited by JamesD
You likely need to loosen the tailpipe clamp and see if there is enough play there to correct the problem.
If not then you will also need to loose the three 13 mm nuts on the muffler mount on that side and the cat pipe sleeve clamp. Adjust them for proper alignment then tighten them all back down.
Thanks a mill Loren,
I'll give it a shot, sounds pretty simple, (famous last words ha ha)
The roads over here in Poland are in very bad shape, pot hole's everywhere, only the big citys have smooth surfaces.
I think the best road's so far on this trip have been in France there even better than the German autoban, much wider & smoother.
