After the engine swap I had no error codes; Now after the hit on the engine and the oil pump swap I'm getting the camshaft 2 position error and misfires in 4,5,6. Is the cam adjuster solenoid damaged; the chain moved when the oil pump was changed; any body got the p0022 in the past?
Car is running ok in the low end but missfires at high rpm's.
Tx,
Sergiu
Edited by sergiu
