We have just replaced the front rotors and pads on our 06 Cayenne turbo s. This one has the huge 380mm rotors with the red calipers and has two socket headed bolts fixing the caliper to a bracket which then mounts to the hub.
It was easier to remove these two rather than the larger ones on the hub bracket but does anyone know what the torque setting for them should be?
I believe the bolts are 12mm x 70mm.
Many thanks
