Hi Everyone !!
Cayenne S 2004 ,
a Warning light (!) , Warning , Brake proportioning !
at first , with the warning lights on i had one speed left 5th gear i think and a weird sound comming from under the car,
but everything was fine when i put the psm off .
back with the problem with psm on.
Now ( abs , psm , check engine lights are on ) Warning , Brake proportioning ! and i cant turn psm off
and cannot put the car in drive without using the emergency lock to unlock it from (P).
brake pads + sensors are new ,all fuses working ,
what could it be , ,,,possible electric problem or ???
anyone with this problem ?
Thanks !!!
Sounds like a sensor of PSM control unit, you need the error codes.
Hi Everyone !!
Cayenne S 2004 ,
Thanks !!!
