P0441 Error Code
The symptoms for this include CEL and Long Cranking times when starting after filling up. Part Required 948 110 202 01 (75 from dealer, 45 from Sunset) Some new Twist locks for the trim panels, since they have a mind of their own. You will need to remove the throttle design cover pull up it comes right off. then you will need to remove the 4 t 30 torx screws on the drivers side coil cover. then that cover will pull up although it is a pain, you can wiggle it out. Use a large flat blade scre
Edited by mudman2
  • 2 years later...
I'm just wondering if anyone has removed the adjacent oil mist separator? It is the larger black round object on the valve cover. I think it might be the source of a small vacuum leak just like the purge valve. Are there any serviceable parts in the separator?
Edited by Ignited
OIl separator must be replaced as a complete assembly. How did you conclude it's causing a vacuum leak?
  • 2 years later...
Many thanks for posting this tutorial.  I changed my purge valve this morning.  With these instructions, took no more than 1.5 hours including setup and cleanup.  Only thing I might add, is to partially reset the metal clips on the injector wiring connections before plugging back together.  Somehow I had the foresight to do this.  I think it was because I realized, as I was unclipping them, that reconnecting was going to be a PITA.  It wasn't.
