I recently purchased a 2005 Cayenne S. If I take the shift lever through the gate to the manual shifting, it will not manually upshift. It will downshift fine. Also the tiptronic buttons on the steering wheel work fine. Any thoughts on what the problem may be? Is there a switch of some sort that has failed? Thanks in advance. I did search this and other forums but to no avail.
The shift gate has switches inside of it on the rubber boot portion... its likely this is your problem but you would need a Porsche system tester check and see if this is definitely the cause (PIWIS tester).
