Hi everyone,
yesterday while i was driving, when i wanted to switch from 3rd to fourth gear the tiptronic switch became loose in the sense that it still works if i want to shift to a lower gear, but when i try to shift to a higher gear the whole unit kind of moves upwards instead of staying in its place and just clicking.
Has anyone had this problem before? i would like to know if it could be that the unit broke or that it just simply "unplugged" itself from its base.
Can anyone give me the instructions on how to mount the new switch?
Romandec
I dont think you can, you may need a new airbag unit
Hi everyone,
Romandec
The switch gear is part of the frame work that holds the air bag but it is a separate part from the air bag unit.
