I'd like to move the DSP from the bottom slot to the next one up, and put a tray that I already have in that spot. Can this be done and what do I need to do it?
John
John
Yes this can be done. You'll need to take trim piece around the DSP module off, and put that on the tray. And take the one from the tray and put that on the DSP module. You may need to cut a couple of the plastic wire wraps around the harness to extend the length, but it should reach.
John
Nope, that won't work. The trays don't have a trim piece. The upper section of the lower console is shorter than the lower section, so the DSP unit won't fit, or, at least I couldn't make it fit. I ended up stuffing the controller behind the console, leaving the CD holder in the upper section, and the storage bin in the lower section.
