Does anyone know where i can buy the Headlight Hex socket tool to remove my headlights for my 2000 Boxster?
In a pinch, there is a substitute common tool that you can use but I can't find the reference with a search.
If I find it first, I'll post it here.
Regards, Maurice.
There used to be a guy on ebay that sold all sorts of weird tools for tamper proof bolts an what not.
PK
Found it! You can use a 5mm socket with an extension or a deep socket. The factory tool is hex female socket, but the metric standard 5mm socket (1/4" drive) will work.
Regards, Maurice.
I take it yours is missing and/or broken from your tool kit inside the spare tire in your front trunk? I had to get my replacement directly from the dealer. I would recommend you call Jeff at Sunset Porsche (link on this site - JeffClark@sunsetimports.com). He'll get you a quote and you can go from there. When I bought my replacement tool it was very inexpensive...that was a few years ago though.
All the best,
Bill :beer:
Regards, Maurice.
That's even better than buying the tool!
Good work Maurice.
All the best,
Bill :beer:
  • 4 weeks later...
Sorry to resurrect an old thread but does anyone know if the 5mm socket works for the MY02 C4S with the xenon headlights? I don't have one long enough and would like to confirm before I order one
The socket size is the same for all headlights.
