Hi. On a 2000 C2 Tiptronic, where are the transmission mounts? i see the two engine mounts in the rear, but I cant see where the tranny mounts are.
I did not know that you owned a tip.
Good for you. I get a good deal of
crap for owning a tip. I am still
faster then most guys with manual.
Paul
On a MY200 Tip - it will be item 1.
I've been wondering about this very issue for Tiptronic cars. If I tackled the rubber mounting replacement, what part do I buy, do I follow what is used on the Manual transmissions? The part is not listed in the parts diagram but I know the manual transmission guys use 996 375 055 05. Seeing as how the side plates are the same part number for both Manual and Tiptronic, I am guessing the also share the same rubber mounting. What do you think?
Thanks. So is it a not-so-bad DIY to remove that carrier? Just hold that end of the tranny in place with a jack, remove a couple of nuts and bolts, remove/replace carrier, ... ?
