:rolleyes: I'm thinking about the short shift option for my Boxster 2000/2.7 5 speed, but I do not know too much about it except that I was told that it is more fun and faster to shift. How much will it cost and how to get it done?
We have put in dozens of them over the years at our local work on cars days. There are now 4 different types, and 5 if you count the special edition.
The EVO unit extends the length of the shift lever at the bottom of the lever. In the old days I think it was the only unit on the market, so that is what we put in. It does not reduce the throws as much as the B&M/Porsche unit.
The B&M unit replaces the shift lever and shortens the throw by changing the pivot point. The Porsche unit that recently came out is identical to B&M.
The special edition does it the old fashioned way. About 1" is cut off the shift lever.
B&M, Ruf, and TechArt make a unit that bolts to the transmission. This unit you can change the reduction in 3 settings. I do no know any Boxster owner that has this unit.
The B&M lever type is about $200 and you can put it in yourself in about an hour. There is a lot of information already on this board on how to install the units.
I tell people to try a car that has one to see if they like it, before buying it. I only know one owner, a 996 guy, who did not like it. And between Loren and I we must have put in at least 40 units.
The interesting thing I have noticed is that the throw reduction with the B&M lever unit is greater with the 5 speed than with the 6 speed.
