Hey Gang-
I have searched and found similar topics but not exactly.....my question:
Is it possible to purchase a slightly used Cayenne key and transfer the guts or circuit from my programmed OLD worn key to the new one without dealer?
I can see how you can pop the cotter pin out and swap the KEY portion itself BUT is it possible to crack open the key itself without damaging it?
THANKS!
Yes, I did it. It splits at the bottom part of the key that has the battery opening. The plastic circle that surrounds the battery comes out ast well (as one piece, with the cover with the emblem on it). You have to be careful winding the spring with the key to get the key to pop out with the button.
