hi,
how can i remove the chrome topcaps from the litronic spray/wash part? i want to paint it separately during installation of a headlamp mask.
only pull? any trick?
thanks!
I believe you have to slide the headlight assembly out. Instructions in your operator's manual. Then you will see the fitting to detach the tube from the "topcaps"
