I think you can only used a thread in style. I threaded in a wheel bolt and after a number of turns it bottomed out with threads left. I do not think the threaded hole in the hub goes all the way through. Plus a normal wheel stud pressed in from behind the hub has ridges so they do not spin - no provision for this on a Boxster.
If someone does it it is going to be with the thread in style and loctite.
But since this is my third car with bolts I am use to it, so it will not be me. And I have never used that goofy alignment tool in the tool kit.
http://www.kyankton.net/Wheels.htm
http://www.renntech.org/forums/index.php?s...entry6972
