Hi. On model year 2000, the failed spoiler light is on, on the dash. What are some typical causes? Any advice is appreciated.
If I recall correctly, the typical areas to look are the harness connection (Open the rear lid and look for a connector that takes the wires from the right rear fender to the rear lid. Inspect the connector looking for corrosion or damaged wires.), hydraulics (you may need to refill the fluid....do a search), fuse (if the spoiler does not actually work) or motor....
