Having recently disconnected & charged my battery on my UK 98 2.5 Boxster I now find both the ABS & Oil Pressure Light constantly on. Oil pressure & brakes function normally. Any idea how to resolve/re-set these?
Try this for ROW (Euro):
Ignition ON
Disconnect GROUND cable from battery
Disconnect POWER cable from battery
Connect both LOOSE cables with GROUND (car body) for 10 minutes
Connect POWER cable on the battery
Connect GROUND cable on the battery
Ignition OFF
Ignition ON
START engine
The warning lights should be out
Note the radio code before you disconnect the battery
Use the window learning procedure
Hi RFM,
Thanks very much for your help. I will try this exactly as you write as soon as I return home in 4 weeks time (currently working offshore in the Gulf of Mexico).
I will drop you a line to let you know how I got on
Regards - Pete
Sorry, forgot to ask exactly what is 'the window learning procedure?
Regards - Pete
Please do a search it's been covered many times. Look for "windows relearn" or "windows training".
