Hi. on a 2000 996. I was wondering if the pink coolant we use is identical to the pink coolant VW and Audi uses (they call it G12).
I thought VW/Audi have now switched to G12 Plus Plus (purple instead of pink) since 2006. The older G12 was an OAT product and from the specs the G12 Plus Plus is a HOAT (hybrid OAT) one that has some silicates with the OAT component. VW says it is fully compatible. As above I suspect that the pink G12 is the same as the Porsche stuff. They even smell the same. The G12 Plus PLus smells different.
