Rev Limiter
EdSanders
Re: Gt3 2004 Rev Limiter
Rev Limiter stage #1 activates at what RPM ?
Regards,
Ed Sanders
So. Calif.
sandersedward@sbcglobal.et
Why no shift gates like other exotics to help prevent the "money shifts" ?
Edited by EdSanders
Correct - it will also not protect you if you spin the car and don't get the clutch in fast enough (you can actually run the engine backwards by spinning the car backwards too).
Loren,
Why no shift gates as in other exotics to help prevent the "money shifts" ?
Ed Sanders
