Does anyone know if 997 floor mats fit the 996 without fitment issues?
I did the search and was not able to find anyone's input. If anyone can help I'd greatly appreciate it as my 996 units have reached their end of life service.
I have 997 OEM rubber mats in my 996 and they fit fine. The passenger is absolutely perfect. The driver's mat is a bit larger than the 996 one around the area where the fuse cover is. I like them so much it's not an issue for me.
Guys I purchased the 997 Standard mats (4 of them) and fitment to the 996 turbo has been almost perfect.
The only bit that had any issue was the dead pedal area. Absolutely unnoticed when driving or daily life. The 997 mats are MUCH higher quality than the 996 in every way.
Not bad at all unless you are very picky.
Drivers fitment again but this is the rail side. ( I used the large plastic screw tacks that come with the mats and the mat won't budge.)
Rear seats the fitment was perfect along with the passengers side.
