The display (LCD?) below the tach has gone dark. That's the display in the center of the instrument panel that shows MPH and air temp. And by dark, I mean that there's no orange-colored light shining through to illuminate the numbers. The other displays are fine. As the display contents are visible under bright lighting, it seems that the backlight has failed. Anybody know how to replace/repair that light? Thanks in advance.
