My right front Xenon headlamp is not working. Does the entire unit have to be replaced or is it possible to just replace the bulb? Is there a DIY guide out there? Thanks for any help!
Edited by Andrew D.
Did you look in your Owners Manual? The bulb replacement specs and procedure are in there.
Loren,
I'm sure you've heard this more times than you can count but I didn't even think of that. I feel like an idiot. It's right there in the manual. Thanks!
Andrew
