2000 2.7L Boxster
CE light came on, threw codes P1128 and P1130.
Runs and idles fine.
I have cleaned the MAF less than 1000 miles ago.
Been running some fuel system cleaner through it.
Any other suggestions? Thanks in advance.
The DME is on his rich threshold for both banks, which means engine runs too lean, an air leak belongs to the possibility's. A good diagnostic tool should give more in formations.
So how do I find said air leak?
Loose clamps or hose on the intake, bad o-ring on the oil filler tub, cracked oil filler tube, cracked AOS, yet another fouled MAF (espeically if you are using an oiled filter), etc.
If you do not feel comfortable checking these things find a good Porsche shop to do it for you.
