Hi guys/gals
So i have done the search and figured out how to release my hood, trunk, and gas cover. I can get the hood and trunk open by triggering the switch on the driver side door panel. The silinoid does work for both front and rear. What i can't figure out is how to keep all three lock free. So this is what is happening. I can unluck the hood and the trunk. Once unlocked i can open and shut my car door then attempt the re-open both the trunk and the hood with no problem by pulling on the latches. Now when i shut the door and hit the key botton on my key the trunk and hood lock up again. I do not know what to do and can't find any posts on this. All i know is that all was working fine till my friend accidentally slammed shut my front hood. It wasn't so much a slam as it was allowing the hood to fall close. Anyone know what's up with all this? I did check the fuses in under the steering column and am now confused what to look for in order to fix this problem
Thank you all
